Maybe I'm misunderstanding, but it sounds like you have both keyboards set to the same MIDI channel, or to Omni. That would be a setting to change in one or both of the SQ-1 keyboards.What do I need to get to allow midi to see both keyboards set on different channels. Right now, midi sees only one, but both will play, causing issues. Both are great keyboards for midi, separately.
Just to clarify the basic scenario here, how are the keyboards connected? My guess was that you were plugging both keyboards individually into the USB ports of a computer (either directly or through a hub), using 5-pin MIDI-to-USB interfaces (since, as Dave said, your keyboards do not have USB on them), and now that you've mentioned Reaper, you've confirmed that you are indeed connecting to a computer (as opposed to some other kind of device), but if you are connecting some way other than through a direct 5-pin-to-USB connection from each keyboard, that would be helpful to know, to be certain I'm not missing anything here, e.g. if there's some other kind of multi-port MIDI routing device between the keyboards and the computer.What do I need to get to allow midi to see both keyboards set on different channels. Right now, midi sees only one, but both will play, causing issues. Both are great keyboards for midi, separately.
I can't think of any scenario where the data could be jumbled, no matter how the two keyboards are connected. What kind of connection are you thinking of, where that could happen?you need a midi merge box. one of its functions is to keep the midi channel data streams 'separated' by channel. many keyboards and peripherals today do not do the midi merge function.
right now the data is being jumbled together causing your issue.
Omni means that something will receive on all channels. So I was thinking that maybe that was causing one of these keyboards to play even when you weren't sending it something on its designated channel. But I forgot that SQ-1 is multi-timbral, so presumably it would normally receive on all channels no matter what (but playing different things accordingly, instead of playing the same thing no mater what). So ignore my suggestion about omni. ;-)I've got them both set to different midi channels (ch1 and ch3) but if not omni, what should I set each of them to?
Unfortunately, I don't know anything about Reaper or the orchestra software. But here are some thoughts I have, which I admit, are total guesses.I'm using the latest version of Reaper and it only sees one SQ-1. I have another keyboard and it sees that one fine, but only one SQ-1. I've tested...it will see each one individually, but not together. I'm confused as to what I need to do.
I do have orchestra software that I run within Reaper and it works fine...I can set any of the three keyboards to play individual sounds, like midi should do. Is Reaper maybe not capable of using two or three midi keyboards at once, except when the software has it's own system setup, like my orchestra software does?
I don't know what that is.I have a 5 in 2 out USB powered box.
If this is for playing on stage (as opposed to multitrack recording) I wouldn't use a DAW at all. To use multiple keyboards to trigger a combination of their own sounds and VSTs, try the free demo of Gig Performer. Other apps designed for this kind of thing are Camelot Pro, Cantabile (PC only), Mainstage (Mac only).Again, I think this is a Reaper issue. But to get help from Reaper people, I have to buy their software. I don't mind doing that, but I'd like to know that the software is going to work for my situation, first. Reaper does have a small footprint as far as DAWs go. I had Qbase for a while,l but it is a memory hog. If anybody has a suggestion of a midi friendly DAW that is light on memory use, I'd be willing to get it a try. I'm not stuck on Reaper. It's worked up to this point, but now that I'm trying to get everything to work at once, to play on stage, it's starting to be come a pain to deal with.
