- Joined
- Feb 14, 2018
- Messages
- 209
- Reaction score
- 67
Thinking of changing my top board. My lower is an RD2000 which Im more than happy with. Takes care of all my Pianos/organs (though I play those from the top synth action board), EPs, Clavs etc - basically all "key" related traditional sounds. The strings and pads are also OK for layering - but not (IMO) up to scratch for solo work.
My current top board is an FA07 - partly because of the price, partly because I thought it would give what I needed. It does, and doesnt.
There are things on it - such as the sequencer - Im not using, some things that I lie but could be better - SNS stuff, arpegiator etc. Some things I love - using the 16 pads to select sounds in a stage set is fantastically easy and quick, but some things its really not good at (not surprising due to price)
What is HAS done, is nail down what I want from my second board. What I want is the BEST orchestral/string/acoustic instruments I can get - but ALSO a VA style synth section - from waveform up. The Latter does rule out the Montage, which probably has the best orchestral/acoustic stuff (from what Im lead to believe).
Im, guessing the obvious choice it the Kronos - though there is a downside - 61 not 76 (or even 73) keys, and I do like that range - but its not a complete deal breaker. BUT while no worse than the FA its real time synth control is limited - though the FX and mod options are better.
Im actually wondering if the DSi Prophet X is worth a look - expensive yes - but Id guess a FAR better synth than any other option - and with the Samples on board, may do the orchestral/accoustic tones well enough? Has the arp and step sequencer which is good enough. Not sure how easy it would be to set up so it can control the RD (for organ tones) without generating sound itself though - and only guessing on the sampled tones.
Is there anything else worth looking at? (maybe a used Jupiter 80?) adn what would be our choice for this purpose.
