61 key or 73 key keyboard with weighted or hammer action?
I'm looking for a home use keyboard, either 61 or 73 key, with weighted or hammer action. Weight not an issue. Based London UK.
A keyboard controller would be fine - it's for input to Garageband on a Mac.
I can see the Studiologic VMK-161+ has hammer action. What are the alternatives? Anything close in a weighted action? Used is fine, even older discontinued models.
I looked at the M Audio Oxygen and I don't think it's the kind of thing I need - I don't need chords, arpeggiator or even drum pad. I would be inputting midi into Garageband and doing the arrangements myself. I would like a weighted keyboard.
I'm wondering if what I need is a poly synth with pitch bend and modulation for designing sounds and playing solo lines.
There are no hammer action 61 key keyboards (to my knowledge).
Keyboards with 73 weighted keys which can serve as a MIDI controller:
- Studiologic SL73 (controller only; no internal sounds). People have mixed opinions about the Fatar TP/100 keybed (some hate it). This is the least expensive option if you don't need a keyboard with its own internal sounds. I have not played on, but I used to own a Nord Electro 3HP which reported used the same keybed. I found it to be somewhat "mushy" (but I gigged with it for years because it was convenient to transport and sounded good).
- Yamaha P121 (home piano with 16 internal sounds). I used to own one. It does send USB midi. Only the original (P121) has a USB audio interface (P121B does not). No pitch bend or mod wheels, and no expression pedal input. The keybed is proprietary to Yamaha. I liked it a lot better than the Nord Electro 3HP (which had better internal sounds however).
- Studiologic Numa X Piano 73 (stage piano). I currently own one. Fatar TP/110 keybed is better than the TP/100. Via USB MIDI or 5-PIN MIDI you can simultaneously control 4 different MIDI channels simultaneously. Also has a USB audio interface. Can send pitch bend and modulation. 3 pedal inputs which are configurable.
JayF
