A-PRO 500 and Garageband
Hi everyone,
I am a total Noob of keyboards and midi.
I am trying to use a Roland A-500 Pro that I got from a friend with garageband but I was only able to male work it only once.
I try to explain myself: I can actually play and use the wheel, but I cannot use the controllers like PLAY, RECORD, AND STOP nor the PADS.
It's seems like the controller is not fully recognized.
I would have give up but using those functions but yesterday I plugged-in and for some reason every was working perfectly, today NOPE, I tried everything, from reinstalling the drivers to use the A-PRO editor to load up new mid mapping, I tried factory reset.
Still nothing.
I have not clue of what I'm doing wrong.
I am on a Mojaves os.
Is here anyone brave and patient enough that can try to help me out? :oops:
Welcome.
You are correct the Mac is not configured correctly but to configure it is straightforward but one thing I am not sure about is if all this will work in Mojave.
Try this
and try using this control surface plug in
There is another option but I will need to be on our Mac to write it up so see how you go with this for now
Mendelw
