Hi. I just bought a Casio wk-7500 keyboard, and I am pretty satisfied with it. But I noticed that when I use the split feature with two tones/instruments using dsp effects, the dsp effect disappears from the instrument on the upper half of the keyboard (the instrument I started with).
For example, I have a drawbar organ preset with vibrato, but when I split the keyboard, adding another another drawbar organ preset, the vibrato disappears from the organ on the upper half of the keyboard (the organ I started with).
Another example is when I use a distorted organ (drawbar organ preset 48), and split the keyboard adding anything else using dsp effects (for example guitar/bass preset 23), the distortion on the organ disappears, and it starts sounding like a regular organ.
The same happens if I record multiple tracks using dsp effects in the song sequencer: Only the latest recorded instrument uses its dsp effects, and all the other instruments using dsp effects gets their turned off.
This is of course highly annoying, and I just wondered if that is the way it's supposed to be? That it is just one of the keyboards limitations, being unable to use two instruments with dsp effects at the same time, rather than something wrong with my own keyboard.
Thanks in advance!
Thanks in advance!
