Accessing "drum keys" on CTK-6000
Kentucky, USA
Hello, very new here and to keyboards. I can't seem to access the "drum keys" on my CTK-6000. The Tone Key has GM/Drums written on it but pressing it does not allow the keys to play the labeled percussion. I've looked through the manual and forums here with no luck. I thank you for any help.
I just checked it on the WK7500. Maybe not the right order but it worked.
I pressed (left) any rhythm section (right) piano or so and than on gm/drums. It did access the drums on the keyboard.
The Y_man
Melbourne, Australia
Which drum set did you select? :confused:
The GM/Drums tone key has many instruments under it than just drums.....the whole GM voice set actually
Also, make sure you auto-accompniment is swithced off
Octave shift to 0.
No transpose.
The Y-man
