Accidentally Lost Flute patch
Does anyone know if you can recover a patch you overwrote? I lost the great factory flute patch on yc61. I don’t want to have to load factory settings and wipe out all my other saved patches. Thanks
Why not just back up your patches on whatever media it uses, THEN apply the factory patches, THEN reapply your patches from backups? That's what they're there for.
Then again on my Kurzweil I can restore a single factory patch with a few button presses.
Check your manual and see if Yamaha incorporated that into their design?
Happy trails :)
I just remembered how to restore a factory patch on the kurzweil.
It's as simple as deleting the modified patch and the system ROM rewrites the factory patch in its place automagically.
If Yamaha designs their toys right then should be all it takes.
