Add layer
Hi I’m new to the forum and have just got myself a pc3x fabulous piece of kit but can anybody tell me how to add a piano to one of the string sounds it does not explain how in the online manual would be grateful for any help you could give me. Thanks in anticipation of a answer.
If you press the QA mode button a bunch pre-created QA banks reside there. Scroll through the banks, one of the banks has a 'piano and strings' program or setup. after you find it, determine if it is a program or setup. Then edit the sound and observe what the programmer did to create it. I believe that the 1st slider controls one of the sound's volume level so that you can maintain the desired balance between the two sounds.
Thanks a lot have you any idea how to change the volume on a new layer I created I can find everything but that
