- Joined
- Apr 27, 2022
- Messages
- 2
- Reaction score
- 0
Hi folks,
I'm new here. I have an old MPK mini mk2, but recently picked up the new MPK mini play mk3, and noticed that in instrument mode the joystick not only controls pitch bend and modulation, but also expression! I thought, "Wow, this was a brilliant use of the joystick!" The only trouble is, the functionality seems to be limited to the built in instrument mode.
If you're familiar with the Akai MPK mini and its quirky little joystick, you know it typically controls pitch bend and modulation. Normally the modulation functionality is simply duplicated across the axis. The function is the same in either direction: you start at 0 and go up to 127 depending how far you push/pull the joystick. But unlike a typical mod wheel, it always resets to zero.
Now this is where the Akai MPK mini play introduces an interesting change in functionality, one that I think makes the joystick more than just a quirky controller. In one direction, you have the modulation (CC1). In the other direction though, it controls expression (CC11), allowing you to dip the expression value down to 0, and bring it back up to 127 when the stick re-centers. This is brilliant!
The only trouble is, for expression to work in this manner, the value has to be inverted so that it's 127 when the stick is centered and 0 when it's pushed to its limit. There doesn't appear to be any way to invert values when using the program editor. You assign a different control change number to each direction of the axis, but the value is 0 when the stick is centered.
Does anyone know how to set this up outside of the built in instrument mode?
Thanks,
Nikko
Thanks,
Nikko
