Hi folks,
first time poster here with greetings from South Germany.
I bought a AKX10 and it is great value for the money.
While so far everything works, I wonder that some basic functions are faulty(?)
Maybe someone can test and confirm this?
Newest Firmware Version 01.03.07. "Lock" ist not enabled.
Global Settings -> Utility -> Config 2:
Usually, a white checkbox means that a function is inactive and a red checkbox means that a function is active.
For the "High Contrast" function, however, a white checkbox means that the function is active (and grey = inactive).
When "High Contrast" is activated, "Breathing Light" means that the function is inactive and a red checkbox that the function is active.
If "High Contrast" is deactivated, however, a white checkbox for "Breathing Light" means that the function is inactive and a grey checkbox that the function is active.
This means that the whole color scheme is inconsistent.
Global Settings -> Utility -> Config 3:
All changes to Year/Month/Day and Hour/Minute are reseted to "2018" after restart.
Global Settings -> Utility -> Config 4:
The buttons for "Backup" and "Restore" are always grayed out and are not selectable.
Group Knobs (top left):
If I switch to "Assign", adjust the three controls (e.g. to min.) and save with "Store" (Bank 001, Peormance Memory 1), the values are reseted to the factory settings when Performance Memory 1 is called up again.
However, if I switch to "Assign", adjust the three sliders (e.g. to min.), then switch to "Cutoff, Resonance, Volume" with the Select button and save again with "Store", the settings remain saved.
If I then switch back to Assign1/2/3 with the Select Button and save again with "Store", the values are reseted to the basic settings when I call them up again.
Greetings, Spectral
Greetings, Spectral
