Exactly!On the right hand side of the keyboard under "effect", is the "part button" turned on. I had what you describe happen to me and I had not turned on the part button under the effect section. Hope this helps.
Yes. This solved the issue. Thank you very much!On the right hand side of the keyboard under "effect", is the "part button" turned on. I had what you describe happen to me and I had not turned on the part button under the effect section. Hope this helps.
Yes. I know. But I can't feel a difference in the sound by switching between Duet, Country Duet, Rock Duet, Trio and so on. Only the '1+5" and "Octave" I feel they works.In the "part effects" screen, under "basic" you see "type". The first box you can select harmony or arp. In the second box is where you can select the different harmony types. Again, make sure the part button is active and that you select R1under part on/off. Hope this helps.
Maybe mine is a defective unit. On R1 R2 and R3 only the "1+5" and "Octave" respond.That's strange. I just went through all of mine and they respond, and I can hear the difference.
I've done the opposite of you. I returned the PSR SX900 because of the noisy black keys. Unacceptable when you pay 2000 euro for a keyboard. I bought the AKX10 and I am very happy. It doesn't sound as good as the Yamaha obviously but the keybed doesn't make any noise, construction is solid, the screen is much better and more cheaper (645 euro)I sent my first AKX10 back because the organ bank ( for the most part) had this strange lfo thing going and turning the Leslie effect off didn’t stop it and the store where I bought it couldn’t help and they said calls to Medeli weren’t returned so I sent it back and bought the Yamaha SX900 that I love! I’m not much on giving up so I bought another AKX10 and this same organ thing happened! This time I decided not to give up and not to depend on anyone else, I found the problem myself!
Since then I’ve had several conversations with the Medeli rep and they really appear to be trying and I appreciate this! Things are stressed now due to Covid and I think my AKX10 will prove to be an invaluable source of inspiration and fun, todays practice just stoked me!
I am a fan!
Do you have your keyboard split?@lonelagranger Returning to the subject of the thread, if I have understood correctly, you can play the entire list of harmonies with your right hand, correct?
Let me check this when I get home.Do you have your keyboard split?
Yes, that is correct.@lonelagranger Returning to the subject of the thread, if I have understood correctly, you can play the entire list of harmonies with your right hand, correct?
