Rambling on . .
I decided to learn to play music late in life . . Aged Mid 50's. . .(now almost 70 yrs old). I chose keyboard for no other reason than there was one (my son's) idle one gathering dust under the bed.
Not easy learning from scratch and who'd of thought taking up music as a hobby would require needing to know about other technical, computer related matters and and needing peripheral hardware etc.
My computer knowledge is totally inept .
Leads me to my query . .
I have two USB sticks both 32g.
Both full of styles!
One has 250 styles and one has 400 styles.
They both work perfectly on my keyboard.
I loaded these files from zipped up files I acquired on line. I muddled my way though my pc and managed somehow to unzip and extract the files.
I want to combine both into one USB.
Each one will not accept the other.
1. How do I transfer one lot to the other. The files unzipped only amount to no more than 2g total.
Some more questions . .
2. Should I start again . . put the whole lot from scratch onto a new stick?
3. Do I extract the files on the stick after transferring from PC or extraxt on the PC first?
4. Do new USB sticks need formatting before any transfer? Mine is a 32g verbatim 3x
5. When and if I get some more files, can I add to this Stick?
6. Can I delete all the files on the previous two sticks and re_use the sticks?
Thanks . . Got plenty of time. . Covid restrictions still prevail here.
Ray
Ray
