Hi! I find that Korg uses dedicated fill-in buttons whereas Yamaha has integrated them in the Main's (with option to turn it off (autofill?). Any advantage during performance Korg has doing so over yamaha? Thanks.
It's probably a question of what you're used to. But that said, I'd think that having a separate button for every possible style section would hopefully give you the ability to choose any one of them as desired, in any order desired-- for instance, Main A, Fill B, Main C, Fill D, Main B, Fill A, Main D, Fill C, Main A, etc.
