Can any of you comment on uploading samples to the Equinox? I recently got the 88 Pro. It contains the DRAM module and I also built in two SIMMs. Very nice, but uploading samples is not (yet) possible. For example, if I try to send short WAV samples via MIDI using Elektron C6 for Windows (the only program I think is suitable for this), the result is heavily distorted sounds. Moreover, sending and receiving the samples is not synchronized with each other, so this method does not work for some reason. But which one?
Any helpful hints much apreciated.
