- Joined
- Mar 27, 2015
- Messages
- 18
- Reaction score
- 7
Here are my recommendations (my .02 cents worth)
STOP when you are experiencing hand, finger or wrist problem.... continuing will definitely make things worse and healing will take longer.
PRACTICE for shorter times.... more often.... is the best way to avoid all these distresses.
Try to practice several different pieces of music in each session..... that way hand movement changes are more varied..... if you play the identical piece over and over for in excess of an hour.... the repetitive nature of the movement is your source of any potential problems.
Finally, you need to select fingerings that suit your specific hand size and shape..... take a look at my suggested fingerings in the video below.... this is suitable for most hands but may not be right for you.... REMEMBER: Fingering is NOT 'cast in stone' .... and most teachers/judges will not even comment on your fingering UNLESS it is impeding your progress or interfering with your timing.
