AX-Edge Bluetooth Connection Issue with Galaxy S23 Ultra
ogr
korea
I recently purchased an AX-Edge about a month ago and downloaded the AX-Edge Editor app to connect it via Bluetooth. The connection worked perfectly the first time, but from the second attempt onward, it stopped connecting. I’ve tried deleting and reinstalling the app and updating my drivers to the latest version, but the problem persists. Interestingly, it connects without any issues on my iPad, but it won’t connect to my smartphone, a Galaxy S23 Ultra (Android).
I’m also curious why it worked perfectly the first time but stopped working afterward. Does anyone know why this might be happening or how to fix it?
I do t have any of your gear but maybe some of my experiences may help you.
I use yamaha bluetooth midi adaptors and have connectivity to anyoif 2 ipads or 2 iphones. Source and recipients include yamaha, hammond keyboards and loopers (rc300/600)
The most common reason I have found for not being abke to connect is thatbit is already connected to anothe device. Ie I want ti connect to ipad1 but its biund with my iphone already.
The second most common is that the keyboard config has turned midi control off.
takis
