B3 on Motif XS8?
Newmarket, Ontario, Canada
If you don't get a lot of bites here, you could try the forums at motifator.com. I don't think many of the regulars here have a Yamaha in the Motif series.
As for which type of sound is best, what genres are you trying to play in? I play the B3 with my Nord Stage, which has a really accurate B3 emulation and lets me control the drawbars, chorus/vibrato settings, leslie speed, and such, just as I could on a real B3. So even if I can't point you in the right direction for the Motif, I can at least talk about drawbar positions for the genres you're interested in.
Something you could try, since I think the Motif XS has sampling capabilities, is downloading a good B3 virtual instrument, maybe the Native Instruments B4-II demo, and sampling the organ sounds that you want if the Motif doesn't have anything that suits your needs.
Sausalito, CA & Ann Arbor, MI
The only problem with download the B3 samples from say NI B4, are that if you're using XS as a standalone (ie, not USB'd into a DAW), then you have to load that sample EACH TIME you need it, as it doesn't retain those samples on powerdown (unless you resample them into XS). That was a big flaw in the ES/XS architecture, as far as I was concerned.
The Vintage C patch is pretty good (so is Cool Cat), and with some tweaking can be a very realistic B3 sim, especially with all 8 slider controls (on XS) being used for the drawbars. I like adding a little more distortion, percussion and adjust the EQ to darken it a little. I've gotten it pretty close to my Hammond Xk3 and Nord Hammond patches, but still sounds a little light when A/B'd to my real B3.
Rajitha
