Best piano action and expression
Looking for 2nd keyboard (88) to get better piano playing action and depth of expression. My Nord S3 isnt the best action, and i notice lack of depth in the midi signal to my Logic Pro studio (right?)
Controller? 2nd stage piano?
Want 88. Want lighter than S3.
thanks for any help
Which NS3 do you have? The Compact (73)? And when you say you want lighter than the S3, you mean lighter than the S3-88? (As opposed to lighter than the S3-73.)
Do you have a budget in mind?
Stage 3 88 is 41 1/2 lbs
Kawai MP11SE is a whopping 74 lbs
Yamaha CP88 is 39 1/2 lbs
Roland RD2000 a whisker short of 48 lbs
Numa X 88 is 30 1/2 lbs
Take a look at the Kawai MP7SE... Great stage piano and midi controller in one.
Roland RD-88 = 30 lbs -- and has 100s of other excellent voices to use as well
Old No7
