Here's what I've got...
* Roland XP-30 (I use this as my MIDI controller and sometimes use the internal sounds)
* (planning to get) Behringer Deepmind 12d desktop model.
* Presonus Studio 24C USB interface for Pro Tools and Studio One, into Mac Mini M1.
Here's what I'd like to be able to do...
* Trigger the DeepMind 12d with the XP-30 keyboard.
* Trigger the DeepMind 12d with MIDI from my DAW via the PreSonus 24C.
* Trigger XP-30 sounds from MIDI within my DAW.
* Record MIDI to, and play softsynths within my DAW with the XP-30.
Can this all be done? I can do away with triggering XP-30 sounds from my DAW MIDI. That's not really critical.
My guess is...
* Hook up the DeepMind to the Mac Mini via USB, which will let me trigger the DeepMind from DAW MIDI.
* Hook up the XP-30 MIDI Out into the DeepMind MIDI In, which will let me play the DeepMind with the XP-30 keyboard.
* DeepMind MIDI Through into my Presonus 24C MIDI In which should let me trigger softsynths with the XP-30, and record MIDI in the DAW.
* Finally, Presonus 24C MIDI Out into the MIDI In on the XP-30, which should let me trigger the XP-30 sounds with DAW MIDI.
Not sure if that's right, or if I'm missing anything. Am I on the right track?
My guess is...
