Best way to program 130 sequential patch changes on a Roland PF 80 or similar.
Need to program Roland FP 80 to sequentially change patches 130 times. Each change must be labeled as to the patch and registration set for rehearsal purposes. Thas means each letter as well as spaces in-between require the programmer to scroll through the entire ANSI character set as well as press sequences of buttons to call up the patches to be stored, the registration sets, and saving the registration sets. Hours of tedious work. Eventually I should be able to click through the program patch changes with a foot switch. What ‘patch change’ software might facilitate this or which patch changer will facilitate this that doesn’t itself program in the same stupid cludgy way with a little window. Is there a better keyboard to use? My platform is Macintosh.
_________________________
