Hi!
I have a DGX 660 Yamaha keyboard, and for some reason, I cant see and read properly the elements in the blue light screen. Does anyone have the same problem? How do I fix this?
Thank you in advance
Check if there's a contrast adjustment in the back of the unit, usually a small potentiometer knob, or if not there, check your manual to see if it's a menu item.
