So my latest issue, is that the PC4 and the montage cannot fit on the same K&M Pro stand. Montage is too wide...sorta means I need to divest the PC4. The nice combo of them both is not going to work as I cannot access any PC4 controls or buttons under the montage. I also need some top space on the stand for the iPad stand. Further restricting space.
So looking for a narrow bottom board, with or without sounds, to do the job. I am guessing the PX-560 and px-3000 are the obvious first choices, just wondering if there are any other decent options out there? Rolands area bit long, and iirc Yammies are a bit long as well.
Suggest anything, I'm listening
