I need a keyboard bag! But I don't know anything about them.
Most of the ones I've seen have 10 mm of padding; is this sufficient? I'll be using it to take my keyboard on two trains to get it to my home, though I may also use it after this for storage. Also I am looking at some with shoulder straps like on a rucksack, so you can wear it on your back, but is this good or bad? Like, will I be using these rucksack-esque things or should I just go for a cheaper bag that doesn't have them? The ones I've been looking at for my Yamaha PSR-E413 are:
http://www.tomandwill.com/ProductDetail.asp?ProductID=81KB25-415&Cat=Keyboard+Cases+and+Bags#
http://www.alltalents.co.uk/Classenti_Keyboard_Bag_CKB1.html
http://www.bonnersmusic.co.uk/buy/Stagg_Music/Budget_99cm_Keyboard_Bag_K10-099
Any other suggestions are welcome. The keyboard's dimensions are 94.6 x 40.2 x 13.6 cm (37-1/4" x 15-13/16" x 5-3/8").
Thank you!
Thank you!
