Ca79 pedals missing need advice
Just purchased a ca79 that was missing it's pedals. It's a fantastic piano.
Does anyone know if the GFP3 pedal set works with this, or where can I buy the correct pedal set for it.
I have messaged Kawai direct but no reply.
If anyone could photograph the GFP3 connector it might help. Thanks
I believe Kawai has very good legacy support.
Have you tried contacting them directly?
Vancouver area, BC
Happy rat, as I just posted in a new thread, we needed a pedal assemblage for our CA950 and Kawai wouldn't sell us one, so maybe they're changing their policy or something.
Deek, try instrumentalparts.com. They were really helpful for my theatre group and they'd no doubt be able to tell you if the GFP3 set would work for you. A man named Carter helped us in purchasing the pedals and they work great. It did take about a month to come, but we weren't in any hurry. I'm singing their praises from the rooftops!
Rajitha
