Cable foot pedal medeli CDP 6000
The cable to my foot pedal, built in into my piano, has disconnected from the plug. I will be able to replace the plug and solder the cables back in. But I am unaware on what the color order is within said plug. Does anyone have an idea?
What kind of pedal? Sustain or Continuous controller.
If sustain there should be only two wires.
It really wouldn't matter which way you wire it up because all that it does is close a switch.
If it's a continuous controller there should be three wires leading to a potentiometer.
Trial and error would not blow anything out. there would only be 6 possibilities.
Take pictures and post them here once you figure it out
Mendelw
