- Joined
- Dec 19, 2018
- Messages
- 6
- Reaction score
- 0
Running Windows 10. Using "Piano Booster" program to run the MIDI files. Using my printer cable to link to my ez-220.
Seems like some MIDI files light up the keyboard and others don't. Also switching through the optional Instruments in Piano Booster is an issue. Many MIDI files have the various instruments in the song and I can't seem to get the keyboard to play the piano part. Many files automatically default to the vocal of the song. Is this a cable or MIDI file issue?
When I use the "Listen" feature on Piano Booster, the keys light up with the song as they should. Switch to "Follow You" and the keys do not light up unless I press them. Is this normal? Pecking the keys to find the right notes is getting tedious.
Also, Piano Booster seems to have some kind of hiccup as it sometimes tries to play two songs at the same time. (the song I previously played and the new song). Is there another program that works better?
Thanks!
Thanks!
