- Joined
- May 29, 2020
- Messages
- 3
- Reaction score
- 0
Hello I have a keyboard casio ca-100 that turns on with batteries but not with an adapter. The adapter works well, I tried changing the switch but it still doesn't work. What could be? Thanks.
Saved me so much time man. Thanks for the polarity tip FrfrThanks yo both of you for taking the time to answer. I embarrassed, I was using the wrong adapter because the keyboard uses a reverse polarity. Thanks again and sorry for bothering you.
mine wont turn on with fresh batteries and i cant find the adapter. do you know what the problem could be?BTW, the Casio CA-100 is worth about $30 on today's used market. If you can't fix it yourself and you're not happy just using it under battery power then it's not worth paying a tech to fix it.
