hi,
im new to this forum and if anyone can help at all thatd b awesome.
i recently decided to pull my girlfriends keyboard out of the cupboard to find out if it was compatible to plugin to my computer.
ive been told i need a midi-to-usb converter or something??
do i need to have an really good soundcard or is the standard usually all good?
my computers only 3 years old and it has a Realtek AC97 card and has Microsoft GS Wavetable SW Synth midi music playback.
ive played midi sounds before just using the pc keyboard on ableton live and using vst plugins so i know that midi works.
my other problem is we moved house and have somehow misplaced the 9volt DC adapter that came with it.
we have since bought another one that had multiple fittings to go into the keyboard but none of them would fit!
so we took it back.
is this plug rare? or is it possible theres something possibly stuck in the keyboards hole obstructing the plug from going in?
if anyone knows a model number of exactly what im needing thatd b T-riff!!
just keep in mind however i need the male plug-to-wall to be that of what we use in new zealand.
kinda looks like this / \
as opposed to this ||
thankyou to all that can help me
so we took it back.
