I play with backing tracks alot, so I am always using the audio in from my iPad. On many of them it seems that I have to max the volume of the iPad to match the key volume of the CTS-1, and this often results in distortion of the backing track. So my 2 options are:
- try to redo backing tracks with higher volume (not entirely sure if that will actually work or if it will still distort, just at a lower iPad output volume)
- lower the key volume of the CTS-1 (as per page 33 in the manual; levels available are 0-127)
Couple questions:
- has anyone run into this and/or modified the key volume on the CTS-1?
- does anyone know what the default volume level is (the manual doesn't say)
One thing I worry about with this is whether it will affect recording output volume when I record through my audio interface.
Couple questions:
