Yes no internal speakers..but the keyboard is plugged into a mixer then thru speakers...not sure if the keyboard can go directly to speakers without mixer but I think we tried that too. I also think I did the suggestion you put on reset..but I'll try again..thanksPX-3S? Yeah, no speakers in that one anyway. ;-)
The info you asked for is in the manual...
Ok if I can find mine..never use them..
I meant px3s is the modelNo headphones plugged in...px- s3
And I reset doing the tone and function button before I turned it on didn't work either
Ok Scott ..I plugged some earphones in and I heard sound!!!!!..But why not thru my mixer and speakers..ugg....do I have to even use my mixer then to speakers ...I think I tried directly to speakers and it didn't work...
No I don't have earphones plugged inWhich model Privia?
(Do you have anything plugged into the headphone jack? That would silence the speakers...)
