Goal is simple - to find sources of synth samples and load them to my Casio WK3500... can someone please provide guidance on the format of the sample sounds I should be looking for"- specifically, let's say I want to buy Prophet or Farfisa sample packs on eBay.. etc... Can someone provide guidance on the file format and type I have to make sure is included? Example - "anything that comes as a sampled sound in .WAV format will work... or ... make sure that the sample format meets these criteria" Next, I assume I need to load some type of file like a .WAV to a floppy and then load the floppy to the Casio. Is it as simple as that? I do have a manual, but find it hard to get to the simplified "how to do it" procedure..
Finally, since I'm a total newbie here... what's the gist of how sampled sounds get loaded and turned into all 76 keys/notes? Example... "you will get a single .WAV file for whatever sound you are looking for.... that single .WAV file is loaded to the Casio, and the Casio figures out how to turn that single file into all of its 76 keys/notes. Once done, it just gets assigned a sound number like all sound numbers. Once you select that number, you get the sampled sound in all 76 notes. Thanks!!! DMS
