Casiotone 701 - Capacitors replacement
Hello there! I bought a Casiotone 701 and while I was playing a hear strange sound and a lot of smoke came out after: one of the two Rifa capacitors is burned. Anyone knows what can be the right replacement? Thanks a lot!
Technically speaking... "It's a fuse."
You probably had a line voltage surge during one the hellacious storms we've seen this year.
Did you manage to find a right one? Need to replace same cap in my organ
Hint.
Do buy and use a quality anti surge / line conditioner power adaptor.
About $25 US and above, avoid the $5 thrift store ones.
Similar Threads
