Celestial Orbs
I started with a single note on my Moog Grandmother that goes into a Boss delay pedal. It has 2 outputs, one dry and the other is the effect. I take both of those outputs and run them into 2 separate channels in my mixer. I use a StudioLive mixer as my interface for my DAW. I had to play with the delay time to get it close enough to a steady beat. I had one channel hard panned left and the other panned right. I have the Moog set so that once I play the first note, the sequencer in it continues to play that note. I can tweak the filter knobs as it plays itself. I had a sound on my Wavestation and just played chords on it. The noise effect is one that I made on my King Korg using the Ring Modulator. I tweak the drive knob to get the sound to sweep and I have a stereo phase on the sound that pans it left and right as well as modulated delay. These are all onboard effects on the King Korg. Then I also played chords and single notes using a few different sounds that I made on my Kronos. I recorded it live into my Cubase DAW. I rehearsed parts of it but what you hear is the first full take of it.
Idaho
Excellent! Thanks. That was precise.
~Bob
The first thing that crossed my mind was "God's Balls" when I saw the title.
The beat was reminiscent of Pink Floyd's welcome to the machine.
Much knob twiddling and filter sweeping going on throughout.
Very well suited to a dramatic score.
Nice job. :)
BTW, try MIDIing up the sequencer in your grandmother to layer up with the other synths for some totally gnarly results.
Stony179
