Changing MIDI Tempo on Yamaha PSR e303
Hi, Could anyone guide me on how to change tempo of a midi file playing on Yamaha PSR e303. I connec the keyboard to a computer, it plays the midi file well but can not change the tempo using tempo buttons and + , - buttons, it changes the numbers but does not realy change on the music playing.
Thanks
Israel
You can't change the tempo from the PSR. You need to either modify the file with a sequencer of sorts, or find a player program that would allow you to change the tempo. Look around synthzone, there's tonnes of useful apps there. I also found this - seems like it would do the trick.
Changing Midi Tempo on PSR e303
Thanks Dave, I dwnloaded as you said, I'll try it soon
Thanks so much again
thisnthat
