complete begginer smooth chord changes
hullo, I'm a complete begginner, I've just been working through chord-book style songs posted on the internet, playing simple triads,
What's been on my mind is to get a smooth change for chords i've been using a different hand each chord change, so i don't have a gap with no notes as i lift my hand to change chord. However, whenever i've seen people playing keys they only use one hand, with no gaps.
Is this a problem of fingering and technique, or is it just practice?
it is mostly practice, but it does help a lot when you know chord variations (C-E-G, E-G-C, G-C-E). That way you won't have to "jump" far with your hand. Also, try spreading your hand a bit when playing a chord. For example, when playing D major, instead of pressing D-F#-A, try D-A-D. It sounds better, especially on lower octaves. Playing chords like D-F#-A may sound blury. :)
Yeah, I've been trying the odd 4th chords (smoke on the water!) and 5th chords, I've been wondering actually about 4ths, are you meant to play them so the first note you play is not the root note? like, say i was fingering D, it would be A - D in that order, as oppose to D - G?
I'm not sure what you're implying... but 4th chords (sus4) are used as chords you put between some other chords, or when there's a chord lasting a bit longer in the song...
There are a few way of playing them but it mostly depends on the song. Just like sus4 chords there are sus2 chords (yup, you guessed it, the 2nd note from the root chord) which are used in the same way.
For example try playing something like this. It's just a very simple progression but you'll hear what i mean:
Ah, Right, I think I understand a bit better now - It's a bit confusing for me cos i have like, no official schooling in music theory, What i know i've picked up from playing the guitar. I thought the lowest note the right hand played had to be the root note, But that obviously isn't the case from your post above, So long as the left hand is playing the rootnote (right?)
I had another question, while farting about i found that if i'm playing say, G (g,b,d as separate notes) and i move my hand to g,c,e, It sounds quite nice: Is this a variation of G or is it a completely different chord? (eg: C) Does it depend on what i'm playing with my right hand?
hehe... ok. this is the thing... What you're describing is called chord variations. You took C as an example so i will too.
Notes in a full C chord are: C, E, G, and the upper C (C-E-G-C)
If you play them in any order (C-E-G / E-G-C / G-C-E) it is alway a C chord, BUT left hand keys make big difference while playing the piano. There's this thing called phatt or fat chords where you play the same thing on your right hand but you do...erm... a form of chord variations in your left hand. That way you make the chords spread around and sound bigger, and warmer.
For example... Try playing C-major then a-minor in this way:
Left hand: C-octave / Right hand: G-C-E
Left hand: A-octave / Right hand: A-C-E
That's a full C, and a full a-minor chord.
Now do the same thing but leave the right hand the way it was, and
play a chord variation in your left hand so you have something like this:
Left hand: A-E / Right hand: G-C-E
The second chord is made out of A-E (A 5th) in the bass, and a C chord on the higher octave. Compare the two chords, and you'll see how much warmer and wider it sounds :)
If you want, I'll do a few recordings today afternoon to make it even more obvious for you.
Nah man, That's OK, I think I get it now, Thanks for all your help! you should write it into a lesson or something for the forum, I think i read something about them adding that kind of thing here...
