Hey all, I'm new here, and a bit behind the 8 ball...
I have a concert tonight and trying to work out a tech problem....
I'm playing a Yamaha C5 acoustic grand with Disclavier DKC 850 control unit...
And sending a MIDI cable out from there, into my old workhorse a Yamaha PSR 3000.
The problem is when I connect the PSR, the only sound I can get from it is acoustic piano (all the "Part" buttons, Left, Right 1, Right 2 - are not functional to select a different voice.... but I'm trying to have it play an electric bass sound.
It worked find when I connected the MIDI IN to a Korg Kronos - so a friend thought it had something to do with the MIDI filter on the PSR. I don't have time to dig through the manual today, but hoping one of you wizards had perhaps encountered the same issue and could lend a hand.
There's a "MIDI" page (where the answer may lie) from the global page...but the on screen buttons don't offer much help or allow navigation to jump to various settings.
thanks and desperate!
Guy
Guy
