- Joined
- Mar 27, 2009
- Messages
- 11
- Reaction score
- 0
is it possible to connect 2 dgx-670 keyboards together to get a richer sound ?
thanks for the reply , what is a midi hub ? is it already in the brains of the 670 ?I mean, possibly with a midi hub. But the PSRsx600 uses the same sound library (but with a latin/Brazil pack pre installed); but you'd still need to use a midi hub.
The PS500 will give you a *much* richer sound, btw. (same sound library as CVP705/CSP170)
