Control mixer with pa4x
abe
LOLO33gil@h
Hello everyone, i hope ya'll doing well
I have a pa4x and a Midas m32r mixer
Here is what I’m trying to do,
In the 4x - songbook I will create a Set List with 5 songs,
I will name them and number them,
like this -
Song1 - #100
Song2 - #101
Song3 - #102
Song4 - #103
Song5 - #104.
In the Midas I will create 5 scenes and name them the same as the I numbered the songs in the 4x
like this-
Scene Line 00 - #100
Scene Line 01 - #101
Scene Line 02 - #102
Scene Line 03 - #103
Scene Line 04 - #104.
So whenever I press a song in the 4x, I want it to trigger the correct scene in the Midas,
So for example, If press in the 4x “Song3 - #102”, it should trigger “Scene 02 - #102 in the Midas,
If I press in the 4x “Song5 - #104”, it should trigger “Scene 04 - #104” in the Midas and so on…,
btw i did try to connect it, and it triggered song1 and song4 correctly, but all the other ones would just trigger random empty scenes like line 61 or 69 (all the other songs in the 4x)
Can you do that all of the songs triggers the scenes correctly straight from the 4x,
And if not, connect the 4x with songbbook+, and connect an external midi device that will trigger both the 4x and the Midas (either straight in the Midas or via the app for the Midas called x32-edit with a Mac) simultaneously with the correct song and scene
Is it even possible to do that?
Thank you
Abe
Canada
I'm not familiar with Midas, but it sounds like you want to be able to switch scenes live on the fly? Can any of the Korg power users help this guy? I can only tell you that Yamaha has designed registrations specifically for what you're trying to do (and Yamaha has been for over 40 years)
Something like this: (an example that's not from my own youtube, for once lol. And yes this guy is much better than I am)
Genos, PSR, StageA, can all do scene changes on the fly. If someone could show him (and me) how to do *this* on a Korg, I'll start putting up PA5x videos as well, because I *need* registrations.
Mark
www.youtube.com/MarkWilburnTLM/Videos
DX7, CLP300, PSR60, Roland E20 + MT32, CVP309, PSRS970, Fender Std Strat, Squier RB3 Midi Strat, Ibanez SA262, Yamaha CG131, Fujiyama FC390, TUC-Kitty
josetabito
