After getting hacked last year and spending a year trying to save my Linux install I finally bit the bullet and bought a mac mini today.
It's an m2 model with 8 gigs of shared RAM and a 512 gig SDD.
I need recommendations on a decent but not overkill DAW, that supports multiple MIDI hardware instruments as well as VSTis. (But mainly hardware friendly.)
I'm migrating from Cakewalk on the PC so something with a similar workflow might be nice.
If it can import cakewalk music files it would blow my mind but I'm just wishing out loud there.
Tried most of the free options on Linux and none of seemed useful or stable.
Looking to spend $200 or less with free updates for eternity if possible.
And I'd rather not clutter up the virgin machine with a boatload of trial installations either.
If you use a particular Apple DAW, please tell us which one and why you consider it to be the best choice.
Also any tips on what other software I may not be able to live without would be very welcome as well.
Now I'm off to youtube to see what there is to see in videoland.
Thanks for listening,
