Corrupt back up file in Korg PA 600
India
I am unable to update from OS 2014 to 2018, When I try to update it says error due to corrupt back up file.
Of late when I use the internal record feature, As I play and record, it starts repeating like a loop after 2 bars of playing.
Try a factory reset first. Then try again with a freshly downloaded firmware update file.
If you are doing this with an SDcard then buy and format a fresh one for the job.
The most up to date OS is version 2.2.
Before you try a reset I suggest:-
Format a new SD card in your Pa
Backup your OS
Create a Save All file
Download OS 2 extract the file and Read The Instructions, then follow them to install
Then download OS 2.2 extract the files Read the Instructions then follow them to install
Check out the Pa to see if all is OK
Load the Save All file to restore your User data.
Korg Pa’s are fussy when updating, the exact process has to be followed
India
Hi Gary, thanks for your quick response, I have tried Factory reset, but the corrupt file prevents factory reset.
Gopu K
I have a pa 600 and its taking ver long to turn on and when it does errors pop up and the screen does not let use the touchscreen and the keys don't work on
Read my response 16 March 2023 and follow the procedures.
Manual page 264 details the Save features and how it creates a .SET file.
Follow instructions precisely especially when reloading User Data, if say you have user loaded sounds if you do not drill down into the Sounds file to your User added files it will overwrite all the Factory Sounds, you have to load individual user added sounds.
On no account select Initialise in the Pa’s Menu system, if you do the keyboard will need to go to a Technician.
Hi, we tried doing the factory reset. We downloaded the new OS put the usb in and restarted but the keyboard responded with the same error messages. see attached.
thanks for your time we really need to figure this out....
