Hi all! I hope i put this post in a proper section
I came here with a dilemma and look for an advice I want to upgrade my current gigging cover band set (actual it's SV1 and KingKorg, with is generally fine, but i want to go for something more practical, better sound and with more capability. I love both of the keyboards for the ergonomy, big knobs and switches, "and all on the desk" ideology, what makes the instruments perfect for live playing.
My assumptions: bottom: very good 88 keys, 3 layers (like Norde Stage, but for 2/3 of his price), lightweight (CP88 beats here RD2000, SV2, Stage3, Vivo S9, or GrandStage), and yep: CP88 for 2100€ seems to have no competition here.
Yes, Nord Stage 3 come with access to Nord Sample Library, but honestly... I rather don't care about it. My principals are: good timing, good notes, good feeling, then good sound...
Last time i had to find a good Choir "Ohh" voice, and yes. I found it in the NSL (after an half hour), and i check'ed the choir in CP88, and both of them were really good. So... For a special quest i have MainStage, Model D (on iOS) or KingKorg.
But the real dilemma is the upper instrument! I want to have an organ/synth/other combo. And here come:
Vox Continental: the cheapest alternative (1000€). It has CX3 sound engine (i give it 4/10 on organ sounds), with can be enough for my needs. XLR is a huge plus, NuTube also. Touchable sliders seems to work fine. Nice synth's and good enough other sounds.
Electro 6D - pros: very nice organ sounds (i rank it 7/10), access to NSL, cons: no mod wheel and pitch bender and it is a big gap if i want to use them as solo synth... I know, it is a organ/vintage sounds oriented keyboard, but all electric pianos i and clav's i want to play on the bottom weighted keyboard, so... 1600€
SK-Pro - it has definitely the best organ simulation (9/10) and very nice interface (4 zones, highly flexible), but the quality of the "other" sounds is for my not adequate at all for the price...2450€.
YC61 - cons? My organ rank: 6/10 (slightly weaker than NordElectro [or just different?], not a huge sound library [but for me: quality>quantity], and... Its all... Pros: user interface quite similar to Nord "zones" system with bigger and more ergonomic placing of knobs and switches, build in interface with (with is extremely practical and i definitely will use this function often, mod wheel and pitch bander, Internal power supply, and the icing on the cake... Vintage switches for sections...
Why i have dilemma? I'm not shure is it a good idea to buy 2 very close keyboards.
Why i consider Vox Continental? Because maybe it is enough for my actual needs and it gives me other sounds than these form Yamaha's?
Why i consider Electro 6D? Because maybe it has really much better organs and the access to NSL is worth attention?
Why i consider SK-Pro? Because it has brilliant emulation of Hammond (no surprise ), but it's astronomically expensive and the "other" sounds are not awesome...
Cheers
Cheers
