I've got an MOX6 and S90ES. Great boards. Unfortunately, I'm hearing a crackling when moving either of the two FC7 expression pedals, for either keyboard. I also have a third FC7 I stopped using for similar reasons. Low frequency, especially bass, presets highlight this irritating sound more than higher frequencies. The contacts in the output jacks are clean, two different amps have been used, the mixer has been bypassed, and I exchanged each FC7 with the other to see if one or both is a problem. It's both. There is no crackling static if there is no signal from either keyboard...just moving the pedal creates no crackling noise.
I wanted to get inside to the rotary pots in each one, but I see no easy way to access them! Any clues to the magic entrance procedure will be appreciated. What am I missing? Is it that obvious? Is there a way to spray contact cleaner more intentionally at the pot when it can't be disassembled, or do I just shove the small straw in the opening I have in the assembled pedal and spray at every angle I can get to?
On the other hand, is this a problem not likely originating with the pedals? What else could be happening? No other volume sliders are exhibiting the problem. Thanks for the wisdom and help.
