CTK-5000 patch file for Anvil Studio
Hi,
If anyone has the patch file(with the .mlb extension),can s/he please share it?
I suppose,using that we can easily assign the actual device's tones to the MIDI tracks in Anvil Studio.
Regards,
Biswajit
If I recall correctly, Anvil Studio has the capability to either use or import Cakewalk INS files.
This one should work for you.
  • Casio CTK-5000 WK-500-v3-.ins.zip
Hi Gary,
Thanks for your response.
I only have the free version of Anvil studio and if I understand correctly,I need to buy the patch plugin to import the instrument definition file and generate the patch file.So currently I don't see any option in the software to load the INS file.So,if the .mlb patch file is already generated by someone ,I can perhaps be able to load it without purchasing the plugin.
Regards,
Biswajit
