CTK-720 USB-MIDI Driver Windows 7 64-bit
Does anyone know of a compatible USB-MIDI driver for 64-bit Windows 7? I found a broken link to 32-bit on Casio's support site, but no luck with 64-bit.
There is a good chance the 32-bit driver will work on 64-bit Windows 7. (But you said the link is broken, so that doesn't really help.)
Have you tried connecting the keyboard to your computer? It might work without the custom driver.
Same Problem here no 64 driver
I also have the same problem when trying to load the 32 bit driver it says i need the 64 version which I cant find.
Rajitha
