I change dthe sample rate and buffer size... And then the crackling vanishes until after some time it comes back
Another excellent point by JDGiants....anything that steals resources from the music software is a Very Bad Thing. Especially anitvirus software, which depending on product and configuration, tries to front-end every i/o the machine executes.I'm just starting with music-making, so can't comment on anything music-specific, but one thing to check for is a low resource condition in your computer. When I'm playing around in a DAW, I have to disable network connection and unneeded background apps (virus detection, utilities, etc) to give the DAW "room to work". Just a quick thought...
Cubase 5 starts Crackling after a short while when playing Instruments.
What can I do to have clear sound again other than restarting the program?
