I've been having trouble with the damper/sustain pedal in my keyboard (RD-300sx). It used to damper the sound when put into the damper pedal input, but now it only changes the volume. When the pedal is set to continuous and is depressed the volume increases, when the pedal is not depressed it makes a very faint sound. When the pedal is not plugged in the keyboard makes no sound. The control port does the same thing (though it varies depending on how the control port is setup). When set to "switch" mode, the pedal doesn't respond (unless in the control port, to switch on rhythm for example). I've read through the manual many times but can't figure out what is wrong.
I tried using the pedal in a simpler keyboard and it worked properly so I don't think its the pedal. I used a different pedal at guitar center (though very similar one in terms of design) and it worked the same way.
The keyboard seems to know what it is doing and is stable, just it is not doing the right function. Any thoughts?
