Hi, I want to use a Studiologic midi bass pedal unit with my Yamaha P80 keyboard. I use the P80 keyboard as a controller for an organ synth, and simultaneously I want to use the P80 as a synth for the bass pedals. I can get it to work ok, but the pedals are velocity sensitive and I can't disable that on the Studiologic. (The sound eventually passes through a volume control pedal, so I don't want velocity on the pedals). If I turn off "Touch control" on the keyboard it doesn't seem to affect the midi controller. Is there a System Exclusive message I could send to the P80 that would turn off the velocity fo a midi connected device? I can't find one in the P80 manual..
Thanks, Lawrie
Thanks, Lawrie
