- Joined
- Apr 29, 2018
- Messages
- 5
- Reaction score
- 1
Can you replace dgx 630 yamaha speakers with more powerful ones. If so what make and wattage, ohms etc. Is it easy to do or do I need a technician.
I would advise that if you can you go to a music instrument store to check out the options.
They are likely to have both options and will probably have a similar keyboard to your to use.
Another question for you.
The headphones on my dgx 630 go ok on other devices and were going fine on the piano.
But now for some reason no sound comes out of the right side of the headset
I am thinking I may have altered the settings (so many buttons) by mistake on the piano which may have caused the problem.
The manual does not specify exactly how I may reset.
Everything else goes as it should
You might want to check the Pan setting on the voices, because it controls the balance between the left and right. A Pan value of 64 is centered, values below 64 are more to the left (0 being furthest to the left), and values over 64 are more to the right (127 being furthest to the right).
EDIT: Also, are you using an adapter to plug headphones with a smaller plug into the larger jack on the keyboard?
