I've been quite excited about the arrival of the DGX 670. Still am...
BUT...
One of the features I was looking forward to is the capability to change the voice of a recorded song. Sometimes after recording a song, I might think a different voice would be better. So how great is the feature? Change it after recording, right?
Well, it's not quite what it sounds like. You cannot save the difference to the song. And in fact, this is the case for ALL of the mixer options in the DGX 670, which are: Volume, pan, style, filter parameters, effect parameters, channel EQ, master EQ, and compresssor. You have two options once you finish with your changes:
BUT...
- Save the changes to a registry, which you would have to remember to pull up when you want to play song
- Make notes of the changes as you make them, and then make those settings and re-record the song.
