A song I am starting on uses Cut Timing. I see no way to set the metronome to that.
So, I set the metronome sesttings to 2/4. But it obviously does not work. It changes back to 4/4. It does actually synch with the playing, but the measure count is off.
Now, If I set it that way and record, it works. But I want it to work when practicing. I won't bore you with why.
Anykone know if it can be done on the DGX 670?
